Good features of MS outlook 2010 portable version
Hello expert, Now I’m using Microsoft office 2007 on my PC. But I want to use MS outlook via USB. So, there is no way to use itin 2007 version. My friend told me in office 2010 there is a portableversionto perform that operation. Can you please, explain me the features of MS outlook 2010 portable version?
Best Answer by Dornfest Rael
Answered By 80 points N/A #183016
Greetings Neil Guyson,
Well I'm sure that MS Outlook 2010 would be nice to have portable but unfortunately such feature hasn't been introduced just yet. Maybe they will in the nearby future. You are not even allowed to install on your USB.
You can try out different email clients such as Mozilla Thunderbird, Portable edition. Mozilla Thunderbird is a well known email software and I'm sure you will find great use of it.
I hope this helps you,
Regards
Answered By 0 points N/A #183018
Hello!
Now you can download the MS Outlook 2010 Portable Version and use it as you like.
Here are three links where you have to download the software from:
First file you need to download
Second file you need to download
The last file you need to download
After downloading the program, just follow the simple installation steps and use it by moving it on you USB device. You can use it on any PC or laptop you want.
The features of the Microsoft Office Portable version are exactly the same as the ones for the regular package. Also, compared to Microsoft Office 2007, the 2010 version has more features and is more user friendly as the previous one.
