Good Mobile Browser I could use
I just got a new mobile phone today and Im planning to install a Mobile Browser for Internet surfing.
What user-friendly mobile browsers I should install on my phone.?
Hey Cgabriel!
There are many mobile browsers for Mobile phones. You have not mentioned the model of your mobile phone. Anyways the best browser for mobile phone is Opera in my eye.
I am using this browser for a very long time. Its interface is very user friendly. You can use it very easily.
If your mobile is Java supported or Symbian or OS or Android than you can easily install Opera in your mobile.
You can search for Opera on internet with its name, like Opera for Htc Wilfire.
I hope that it will help you a lot.
Thanks
As you have not mentioned which mobile you are using and what is its model. So the following browser is the best mobile phone user friendly browser that I have used so far.
Skyfire is the best browser because of it is user friendly and its features. Here is quick view of Skyfire features:
1.  Its loading time is faster than opera when we watch videos.
2.  It has flash support.
It also supports web pages with Ajax, Quicktime and silverlight
Since you did not say if your handset is Android or iOS, I will just assume that you are using an Android phone since it is the mostly used phone around the world. I know every Smartphone has a pre-installed web browser and normally Google is installed. But if it doesn’t have it and a generic web browser is installed, try the following mobile web browsers:
