Good wireless security for Cisco equipments.
Which wireless security technology is a good choice when using Cisco equipment in conjunction with operating systems such as Windows and Linux?
Dear Heaven,
The best form of wireless security technology to use when using Cisco equipment in windows or Linux operating systems is the CSD. This capability helps in reducing the chances of any form of risks. The CSD does this by being compatible with the windows and the Linux operating systems. CSD further achieves this task by encrypting all the data and also files that are contained in the computer or laptops. It provides adequate protection in case of any occurrence of abruption sessions and also time outs. Additionally this security technology protects all forms of downloads, cookies, temporary and also the history documents. Advantage of this technology is that it can easily be customized thus able to work in all the Cisco equipments used in windows and Linux OS.
