Is Google the best maker sketchup to build my architecture draft ?
Hi guys !
I heard that the maker sketchup of Google is the tool to use when you want to make sketches of buildings.
However, I have recently read that this same Software is frequently used for creating 3D buildings for Google Earth, is this true ?
May you guide me understand the utility of such a Soft ? and tell me if I should use it in Architecture field ?
Thank you.
Answered By 5 points N/A #160157
Google SketchUp is easy to use, fast and reliable. I had used Google SketchUp for making 3D church and I really enjoy working in this program. You can download from https://www.sketchup.com/download. On this site there are also a lot of video tutorials for every tool how to use it, step by step. Also you have Google 3D Warehouse where you can find a lot of models that you can modify. With SketchUp you can create, modify and share your 3D models. I think that you can make model buildings for Google Earth.
I hope this tip will help you!
