Google Chrome always crashing after 5 minutes
What can I do to solve this problem? A am using the latest version of Google Chrome but still I always experience the crashing problem. I even re-installed it and clean my registry using CCleaner.
Try and fix your Browser profile. You can find help from Google on this here:
It can also be that some of the Firewall installed in your system is doing this with Google Chrome. Turn Firewalls and Antivirus off for some time and check if Chrome still crashes.If you don't face the issue now, then you have to create an exception for Google Chrome in your firewall/ Antivirus.Then enable Antivirus / Firewall.
You can get more help on this from the below provided Google Chrome link. Have a look here.
