Google Chrome available for iOS
I just learned that you can now install Google Chrome for the iPhone or iPad.
Will you be getting easier-browsing experience like on your regular computer?
Most chrome features from android or in laptops will be available in chrome in iOS, So the experience that a user can do with a regular computer can be experience also to iPhone or iPad.
So easy browsing that you are looking for will be available. It will be advantageous for chrome since many desktop or laptop users use chrome for internet browsing.
But Google Chrome will not be the default browser for iOS and it is slower and can't be faster than another iOS browser like Safari, because safari and other is browsers uses a Nitro engine that make them faster.
Hope this helps.
Hello Adam,
You will have an awesome experience when using Google Chrome for the iPod or iPad. Some of the features you will encounter are the following;
You will be able to easily open and switch between an unlimited number of tabs. On your iPhone as well iPod Touch, you will be able to flip through tabs the way you would fan a deck of cards. When using the iPad, you can be able to swipe from edge to edge to switch tabs.
You can easily navigate with a simple, as well as streamlined browser. You can utilize the Find in Page to look for specific words and then scroll to see each match.
Carl
