Hello there,
Downloading Chrome Browser from the Play Store fails every time with this error. I don’t know what to do anymore because it seems like I am the only one with this error. I tried to download using Wifi and 3G all with the same result. Can anyone help me please to fix this error ? What is the problem ?
Thank you !
Error
Update for ‘Chrome Browser-Google’ could not be downloaded due to an error. (403).
Google Chrome Browser error downloading the updates
Hi James,
I have read your problem. Error:403 generally happens when you install an app from other resources than play store. If you are using a Chrome downloaded from third party websites, then uninstall the app and do a clean install from the market.
You can also try the following:
Go to Settings
Tap Accounts
Tap Google and remove the Gmail account you are using to download from the Playstore.
Add the account again.
Try to install the update.
Hopefully this will solve your problem.
Hi, this could be a problem with your play store to firstly check you internet connection is fast enough because sometimes though you have good connection play store fails to download the apps. So make sure your connection is good at the moment than go to your phone settings and application manager then clear playstore cache and data then try to sign in again in play store then download the google chrome browser using play store it will work.
