I have just made a clean install for windows 8 PRO on my pc. I am having issues with the installation of goggle chrome. When I first got it on my system, it installed just fine but it was constantly crashing after a few minutes of use. I tried to uninstall the software and reinstall it immediately. Now I am faced with an error message saying that it cannot go through the installation.
Google chrome crashing and reinstallation failure
Hi, Robert!
It is all due to virus infections. When a virus infects a single file and we run that file, then it spreads the virus in whole computer. Here you have infected file that is related with your Google chrome browser. So when you run the Google chrome, the virus begins to spread all around. During this, the virus damages all running files and other profiles are being damaged by it. Just scan your computer with antivirus to overcome this problem.
Next what you can do is: Clean temporary files, restart the windows and try again. Now if you really think something is wrong, you should try to bring it to the default settings. To do that:
1. Open a new tab and go to chrome://settings.
2. Scroll down and click Show advanced settings.
3. After expanding the section, scroll down and find out the button saying Reset browser settings.
4. If asked, click Reset.
Now, your Google Chrome is at the original state.
Mathew
Your install file may be corrupted. Download it again and attempt an install. Also, ensure that the file has the necessary system permissions to execute. If that does not work, acquire and install an older version of Google Chrome. If you still encounter problems, conduct system maintenance: defragment, wipe free space, erase junk files, run a virus scan, and update your OS.
