Any one received the similar error if I exercise the current profile? If so let me know if you have fixed that issue and what steps you followed to resolve it.
Google Chrome
Your profile can not be used because it is from a newer version of Google Chrome.
Some features may be unavailable. Please specify a different profile directory or use a newer version of Chrome.
OK
Google Chrome error message ?
Hi Rhonda A Inouye
I can suggest you check your Google chrome if its updated. try your Google chrome reinstall it so that you have new update. But you can choose other way to fix it.
just do the same way am gonna give you so that you can fix it correctly.
I have link here to fix it hope this will help you to solve your problem
Thanks & Regards
Hi Rhonda,
There was an issue with the newer version of Google chrome and the update, so what you do is just delete the Default file from Chrome this will automatically let Chrome detect the updated version. Here is what you will do navigate through C: > Users > “UserName” > AppData > Local > Google > Chrome > User Data > Default. This should resolve the Chrome issue.
Hi Rhonda A Inouye, If you have this error on google chrome I have an opinion you can reinstall your chrome or download newest and updated google chrome.If you choose to fix it I give the following steps. Step 1 – Launch Windows Explorer Navigate to C:UsersYOURUDRTNSMRAppDataLocalGoogleChromeUserDataDefault. Step 2 – Locate the file called “web data” Delete it. Step 3 – Launch Google Chrome. The error message is gone!
