Google chrome installation on linux ubuntu
how do I install google chrome on my linux ubuntu operating system,and does it really enhance the browsing speed?
It’s very much easy to install Google Chrome in Ubuntu. You do it in several ways. You can use Software center to do this. Otherwise you can download .deb file of Google chrome. First one is easy step. Go to "Software Center" It will be in your "Application" menu. Then search for Google chrome. You will found Google chrome in there. Click it to install. Now you will found "Google Chrome" browser in your application list. In order to download Google chrome directly. go to www.google.com. Search for "Google chrome". click on that & download it from that site. You will find .deb file. By double clicking, it will install. I think Firefox is better for Ubuntu. Chrome is little bit slow in Ubuntu
The following steps will help you install Google Chrome on your Linux OS:
Carl
