Rexon Ros
Posted on - 08/22/2011
I can’t install Google Chrome in my computer. I downloaded the Chrome installer from Google (the online installer). At Around 60 percent, the installer stopped downloading files . It just hanged there. I waited about 3 hours, but no change in the progress bar! What is the problem?
Austein
Google Chrome Installation Process Stops at 60% and Hangs
Hi!
It is advisable to seek an alternative Google Chrome installer to avoid the problem that you are experiencing right now. Example: Offline installer.
You do not need to have the network connection to install this installer. It will be easy for you. Once you have installed this, it would automatically try to update from the web to its new version. The only problem is your network configuration will not let you do this due to security reasons.
At this time it is better you check the latest version through this URL and manually install:
You can get further help through https://support.google.com/chrome/?hl=en
Cheers!
Dank
This happens when computer is filled with junk files. These corrupt files may prevent you from installing the program properly. Cleaning the junk files using a reliable program, may resolve this problem.
You can download and install Reginout System Utilities to clean junk from computer drives and registry. This program automatically detects and cleans all the errors in just few clicks.
Best Regards.
Hello Dear,
It seems that you have downloaded Google Chrome from an unauthorized website, or you have downloaded a Google Chrome package that has viruses in it.
It is also possible that the package is corrupted, so that you are having this problem.
I suggest you download the latest, full, and secure version of Google Chrome.
I will give you a link to download the virus free Google Chrome package.
https://www.google.com/intl/en_uk/chrome/browser/
This is an authorized website, and it has virus free setup. Enjoy. Thanks.
