S Patel
35 points
Posted on - 08/05/2016
I am having trouble connecting to the Internet via Google Chrome. There is no problem in the router as IE is running. Any solution as to why Google Chrome isn’t working but Internet Explorer is working fine?
Google Chrome Isn’t Working But Internet Explorer Is Doing Fine?
It can happen if you have re-installed the Windows or Upgrade them. When it is complete, Chrome’s settings are changed, and it may not work fine on your PC. But, it is no worry, and no rebooting of the system is required. All you have to do is:
Go to Chrome and then move to Settings from the top right corner of the screen. After that, click on Network > Change proxy settings, and then click on Change LAN Settings. Now, deselect the checkbox of ‘Automatically Detect Settings’, apply the changes, and click on OK.
