It started doing that this morning all of a sudden. When I open a webpage it stays open for about ten seconds and it redirects to a black page. I uninstalled it and installed a fresh copy form the official site, but this couldn't help. What might be the problem with it?
Google Chrome keeps redirecting to a blank page
That’s quite unusual for a web browser to automatically redirect to a blank page. I’m not sure if there is something wrong with the settings because there is not much option to configure Google Chrome. Try checking your computer for any virus. It is possible that there is a malware that’s affecting the application and the system. Update your antivirus then run a full system scan on your machine. If there is no problem with the system or there is no error in the file system, the application will surely work. But since you are encountering this odd behaviour in the application, try checking your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit.
It’s better if you uninstall Google Chrome first before doing a check on the hard drive. After the disk check, install Google Chrome again. If the browser still behaves like that, try replacing your browser with a different one like Mozilla Firefox maybe or Opera.
