Google Chrome Portable 19 compatibility
I’ve heard about the latest Google Chrome Portable 19.0.1084.52. I need to know- which operating systems are suitable for using this software?
Google Chrome Portable 21.0.1145.0 Dev / 20.0.1132.11 Beta / 19.0.1084.52 is the latest version of Google Chrome Portable. This version was just updated last June 2, 2012. This version of Google Chrome Portable supports Windows XP, Windows Vista, and Windows 7 operating systems regardless of the Service Pack it uses.
If you are a long-time Google Chrome Portable user, I’m sure you already know how the upgrade for this program is done. Each new release needs to be downloaded separately and you need to install it on top of the older version.
To download Google Chrome Portable 21.0.1145.0 Dev / 20.0.1132.11 Beta / 19.0.1084.52, Please visit Softpedia.
