Google Chrome Program Error Code 0xc0000005
I received this problem after I downloaded and installed Google Chrome:
Chrome.exe Program Fault
The Software never initialized effectively (0xc0000005). Press on OK to eliminate the program. I removed chrome extensions and restarted my PC. I am using Windows XP SP3.
Is a problem with my installation?
Thank you.
