marc shane
60 points
Posted on - 07/05/2011
My dear friends,
I was browsing an ad posting page on Google Chrome to post some ads of mine. Â Meanwhile this error appeared and the site page didn't explore.
I don’t know what happened because just half an hour ago, I  visited the same site page and had posted ads, and now when I tried to open it, I was facing this error message.
Something went wrong while displaying this webpage. To continue, press Reload or go to another page.
Please help me as I have purchased registration to this page to post ads. If this page doesn’t explore, I will loose my daily online work.
I tried also to open this page in other browser such as IE 8. There, Â it was working fine. Yet, I want it to be explored on Chrome because it's the requirement of my employer to post ads via Chrome explorer. Â
So, if anyone of you knows how to fix this problem, then please do help me.
I will be waiting for your kind reply.
Google Chrome Site Visiting Error
I’ve been in this problem few weeks ago. I tried to find some solutions over and this one works great. Follow the solution given below and hope it will solve your problem.  Please try this solution:
use the — no sandbox option in Google Chrome by just simply appending –no sandbox on the target line (e.g. "C:Documents and SettingsAdministratorLocal SettingsApplication DataGoogleChromeApplicationchrome.exe" –no-sandbox).Â
If not: Try to reinstall Google Chrome.  Maybe some files related to Google Chrome were corrupted. Uninstalling and reinstalling it  is a kind of trick that sometimes works.
If none of them seems to work, Â please Uninstall the following programs: Flash, Shock ware and any Java Plugins. Â It seems that they are not fully compatible with Google Chrome as of now. Try to update your Google Chrome browser. Â Maybe there is a newer version available as of now that rectify this kind of issue.
