“Google chrome for win ce”
Google chrome is a good web browser. Many advantages are available in Google chrome for windows ce. You can take control and customize it. It is a faster browser. It is secure. It supports advanced plugins. Supports html, java scripts and so on. Most often it does not require external plugin. It works as if every things are built on it.
Hi Chathuri,
Google chrome is not available for Windows CE. In Windows, It is only available for XP, Vista and Windows 7.
If you are looking for a good browser for windows CE, there are two browsers officially supported by windows CE,
Each browser is optimized to handle different device requirements. And which one is suitable for you depends on the usage requirements by you. Whereas the later versions of Internet explorer for Windows CE support advanced features similar to Google Chrome such as tabbed browsing, private mode and JavaScript.
There are other browsers also available for use with Windows CE such as,
Firefox released a version specifically designed for mobile devices and provides all its features such as tabbed browsing (being able to open several tabs in a single window), Privacy mode (similar to incognito mode on chrome) and the ability to bookmark webpages for easy access later on.
Opera Mini for Mobile devices works on Windows CE. It provides features such as tabbed browsing, bookmarking, and the ability for horizontal and vertical viewing of the browser.
Hope this helps.
Beginning the technical point of observation:
Benefits OF “GOOGLE CHROME”:-
1. It has a very straightforward design, which allows us to browse faster than any internet browser out there.
2. In Google Chrome, you can get wherever on the Web with individual box.
3. ”GOOGLE CHROME” relate with bookmark facilities.
These are all the advantages for Google chrome.
