Google doc’s when multiple people edit how can we know who changed.?
Hi All,
Google doc's when multiple people edit how can we know who changed.?
What i want to know is which cell who changed out of 5 people who work on the excel file?
Is there anything we can set to find out.?
Thanks
Brightday
Best Answer by Alcaraz Jody
Answered By 0 points N/A #94919
Hi Brightday ,actually what you have asked is the downside of Google Doc's, you can't easily know who made what edit unless people editing indicate a text who made what edit,or have some color coding who made what changes,since the number of people editing the documents at the same time is limited.
Hope this helps.
Answered By 5 points N/A #94921
Dear Brightday,
You can know who edited you document on Google docs by a feature called revision history you can see changes made to your document and who made it also you can revert this changes and return your document to its original shape. These features apply for Google docs and other types like power point or excel files.
You will find more details on the following link
https://support.google.com/drive/?hl=en
