Google earth flight simulator controls Macbook air
Hello all,
Google earth flight simulator controls macbook air
Thanks in advance
Wach
Best Answer by oliverpowell
Answered By 0 points N/A #158237
Yes it is possible to utilize Google Earth Flight simulator on your MacBook Air. Follow the steps below to achieve it:
1, Launch Google Earth and then go to Tools and Flight Simulator.
2. Press  + Option + A on your Air keyboard.
3. The Flight Simulator window will open. Choose on the following criteria:
 – Aircraft
– Start Position
– Joystick Support
4. To close the Flight Simulator, simply click the Exit Flight Simulator
Thanks 🙂
Answered By 50 points N/A #158238
Entering Flight Simulator
To enter the flight simulator, do one of the following:
  • Click Tools > Enter Flight Simulator
  • Press CTRL + Alt + A ( + Option + A on the Mac)
The Flight Simulator dialog box appears. You need to chose the following:
  • Aircraft – Choose the airplane you would like to fly based on the descriptions shown. The SR22 is a slower plane and easier for beginners.
  • Start Position – Choose where you would like to begin.
  • Joystick support – Check Joystick enabled if there is a joystick device on your computer that you would like to use.
To change these settings, exit the flight simulator and press CTRL + Alt + A ( + Option + A on the Mac)
To view this page at any time,  press CTRL + H. (Windows and Linux only).
To exit the flight simulator, do one of the following:
  • Click Exit Flight Simulator
  • Press CTRL + Alt + A or Escape (+ Option + A or Escape on the Mac).
