Hi guys,
I have been using Google Earth to view satellite images but recently I have been seeing a plug-in error as shown below. I do not understand what happened please assist.
DanTouchEarthPlugin plugin failed to load.
The Error was:
Method not found: ‘Worldwind.WorldWindow WorldWind.MainAplication.get_WorldWindow()’.
Google Earth Plug-in has encountered an Error
It is an obvious plug-in error in Google Earth. But even if it is only a plug-in error, make sure first that your computer meets the necessary requirements to run Google Earth. Running Google Earth doesn’t really require that your computer is on the high-end level. You can run it even on a Pentium 3 500MHz processor.
For Microsoft Windows, it supports Windows XP, Windows Vista, Windows 7, and Windows 8. And since you are using Windows XP, you are pretty much within the scope. It also supports Mac OS X 10.6 and up and Linux kernel 2.4 and later. In Google Earth, when the problem is somewhat related to its plug-in, your first option is to try reload the page.
If reloading the page doesn’t do any good, you may re-install the Google Earth plug-in. To download the installer for the Google Earth plug-in, visit Google Earth Plug-in. This is the direct link to the setup file of Google Earth Plug-in. Run the installer after the download to re-install the plug-in.
