Hi TechyV,
My Google earth software is not working. I was trying to install Google earth version 5 on my windows 7. But every time a problem rose showing a message error code 0x80040905. I tried for reinstallation a few time before posting this message. Help me solving this.
Waiting for your response?
Hi Hunter Chasee,
I searched a possible solution for your problem. Seeing 0x80040905 error follow these steps that may solve the problem:
1. Click Start, Click Setting then control panel.
2. Double click on Add or Remove Program.
3. Scroll until you see “Google Earth”.
4. Click on Remove, then Click Yes then Finish, an Error will prompt but you can ignore it.
5. Now Download Again the Latest Version of Google Earth using this URL.
I will ask you to run a system recovery or set your system to an earlier state. The new version you are trying to download does not supports your OS and you are getting this error code or the key you are using for the program is not valid. Check these both and you will be able to run the program.
Smith Thompson
