Hi Friends,
Do anyone familiar with Google Event Manager Software, which will help me to create multiple events in minutes and set the RSVP limit for each event or select cutoff time. I need to have similar software for my Android phone, is it possible,
Please guide me on this,
Matthew D Martinez
Google event manager software for Android
Hi Matthew,
The 'Event Manager Lite' is used for creating events for the android device.
Download the software from the Event Manager website.
The features provided by the application are as follows:
1) You can create an event for registering attendees names, phone, email, company
2) It helps you enter short notes for the respective event
3) It captures the image of the attendees and attaches those images to the profile
4) You can save the file with .csv extension
5) It has check-in feature to search for attendees and view their details quickly
6) It manages the list of attendees present in the list
