Google Map problem on Droid 4
The following error message is popping up when I try to open maps on my Droid 4: "Sorry! The applications Maps (processcom.google.android.apps.maps) has stopped unexpectedly. Please try again." It then closes forcefully. Can anyone help please?
Answered By 590495 points N/A #151151
If this is the first time that this happens on your application, try restarting your phone then open it again. If it still doesn’t work even after rebooting your phone, you should check again the site where you downloaded this application and verify the system requirements of the program. You should check the type of phone that the application is designed to run and since it requires android you should also check the version of android that is required for the application to run efficiently.
You may also try reinstalling the application if you still have its installer.
