Google Maps and Siebel have suddenly stopped loading
Someone sent me an e-mail regarding Siebel. The sender indicates having no problem using Google Maps and Siebel until it recently stopped loading one map. An error page says "This content cannot be displayed in a frame".
This content cannot be displayed in an frame
To help protect the security of information you enter into this
website, the publisher of this content does not allow it to be
displayed in a frame.
What you can try:
 â€“ Open this content in a new window. Why did it stop working all of a sudden?
I need your suggestions.
Best Answer by Hathy greave
Answered By 0 points N/A #134678
I think the issue is related to Internet Explorer. So, do the following and get solved:
1. Open your IE and go to the 'Tools' menu and select Internet Options.
2. Select here 'Privacy' tab.
3. Click on the 'Advanced' button.
4. Select 'Override Automatic cookie handling' checkbox
5. Select 'accept' under 'First-party Cookies' & 'Third-party Cookies'.
6. Click 'OK'
Now try to use.
I think your problem has been solved.
Hathy
Answered By 0 points N/A #134679
If this is a sudden stop, there could be two reasons.
01. Something wrong in your side
02. Something wrong in server side
To rectify what is the wrong in you side, try to use different browser i.e chrome, and see whether the error occurs.
If that browser working fine, you reset your default browser to its original settings and you will through with the problem.
Share your feedback in order to assist you further.
