Please help me with my Lenovo K1 Idea-Pad that I purchased recently, I had trouble in downloading several apps from the android apps store. Every time I tried to download and install the Every trail, the response from the downloader was I need to update the Google maps, but I couldn’t use the Google maps every time I try to use it and I couldn’t use the Every trail also because it is not loading.
Google maps error with Android apps
If you do not recall downloading Google maps using your android application, then Google maps could be part of the applications that have been saved on your phone, and you might have tried to run its updater recently but it did not finish successfully and everytime when you try to access the internet the updater prompts you to finish the Google map update first.
You will need to do the following:
Finish running the Google maps update.
Remove all the browser cache files and browsing history if you do not want to continue with the Google maps update so as to remove any Google maps links from the phone browser.
That should help.
Regards
Thompson Locker
