Google Nexus 5 Headphone Gives Sound in only Left Earpiece
Headphone Jack of my Google Nexus 5 Smarthphone is having problem. When I plugged in my brand new Skull Candy headphones into it to enjoy music, I noticed that sound from only left earpiece was coming. There was no sound from Right earpiece. I used the headphones in my Nokia phone they worked fine but Nexus 5 is having issues. Please help.
Answered By 590495 points N/A #145914
If it is only the left ear that is working on your brand new headphone when using it on your Google Nexus 5 Smartphone, that means the jack is not inserted properly or all the way to the port. Try pressing on the jack a little bit more while playing music perhaps to see if both ears are now working.
The connector size used on Skullcandy headphones is 1/8 inch or equivalent to 3.5 millimeters. That’s why it is perfectly compatible with your Smartphone. If you really can’t use the Skullcandy headphones on your Google Nexus 5 Smartphone, try using a Bluetooth headset instead. This way, you can be assured that the headphones work since both devices support Bluetooth.
You just need to pair both devices and make sure the headset is fully charged to enjoy music.
