I have Google Nexus 5 which has a problem with auto focus (when moved the image on the screen will remain blurred for a long period of time) and sometimes it will freeze when taking photos, what could be the problem with this Phone? How do I fix this?
Google Nexus 5 features have some common problems with 8-megapixel camera module, slow auto-focus and shutter lag. Which is better is that problems are made by the software and not by hardware, and can be solved by installing a new OS or install a new firmware update form Google.
Google has released the Android 4.4.1 update, which directly addresses the camera issues. Update features: a much better focus, a better white color balance for day and night, ability to pinch-zoom the viewfinder mode and less shutter lag.
If you have a problem with your phone’s camera, try factory resetting your device to restore the original factory settings of the phone. Before doing a factory reset or master reset, back up your phone’s data to your microSD card and your contacts to your SIM card. Once everything is backed up, remove your microSD card and SIM card from the phone.
To perform the factory reset or master reset on your Google Nexus 5 Smartphone, on your home screen, tap “All apps” icon then go to “Settings”. Scroll down to “PERSONAL” then tap “Backup & reset” and then “Factory data reset”. If your phone is password-enabled, enter your pattern, PIN, or password when you are prompted. Finally, tap “RESET PHONE”. Here are your phone’s specifications.
The LG Nexus 5 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, and LTE technologies. It was announced to the public on October 2013 and released on November 2013 measuring 137.9 x 69.2 x 8.6 millimeters and weighing 130 grams. It uses micro-SIM card and built with a plastic body.
LG Nexus 5
It has True HD IPS+ capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass 3. It ships with Android 4.0 Ice Cream Sandwich upgradable to Android 6.0 Marshmallow powered by Qualcomm MSM8974 Snapdragon 800 chipset, 2.3 GHz Quad-Core Krait 400 processor, and Adreno 330 GPU. It doesn’t support microSD.
It runs on 2 GB RAM with internal storage available in 16 GB and 32 GB capacities. The primary camera supports 8 megapixels with f/2.4, 30mm, 1/3.2″, 1.4 µm, and OIS featuring LED flash, autofocus, geo-tagging, touch focus, panorama, HDR, and face and smile detection. It can record video in 1080p at 30 fps. The secondary camera supports 1.3 megapixels with f/2.4, 1/6″, and 1.9 µm.
It has 3.5-millimeter jack with active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP support; GPS with A-GPS and GLONASS support; NFC; and microUSB 2.0 SlimPort with USB Host support. It doesn’t have stereo FM radio. It has built-in accelerometer, gyro, proximity, compass, and barometer sensors. The pre-installed web browser supports HTML5.
It runs on non-removable Li-Po 2300 mAh battery with standby time up to 300 hours on 3G and talk time up to 17 hours on 3G. It is available in black, white, and red colors.
1....
