Google Nexus 7 for others
Is it true we may not be able to access the TV Shows magazines and other stuff for non residents of US ? How can we access those ?
Google Nexus 7 is a custom build version. So the system has some features locked for certain regions of the world. Hence, you better check the features depending on your area to go for the best option according to your requirement and current location.
Hope this would helps.
In addition to that, you can contact your network carrier to get more information about the locked features of Google Nexus 7.
Hi Yvonne Gresham,
I understand that you would like to watch TV on your Nexus 7. Nexus is a thin light weight tablet that was designed for Google play.
It has 7 inch clear display and its battery can last all day long. In addition it has up to 32 GB of storage space to store mobile data. It supports up to 200 GSM providers. It has quad core processor and is therefore very fast. It also supports thousands of games from Google play. You can watch TV on the device without hassles. Residents of US can access thousands of films, TV shows and magazines too. You can check this to know more about Nexus 7.
