ave broers
70 points
Posted on - 11/21/2014
I am planning to buy this Google Andoris 5.0 Lollipop. I was told by my friends that this device has several better built in Operating Software features than the Kitkat devices. I really don’t have idea about this. Can any one please suggest me with the better solution? Thanks in advance for your suggestions.
points
Is Google’s Android 5.0 Lollipop better than Kitkat?
Android 5.0 is the latest edition of Android with more awesome features and improvements, allowing robust and amazing conveniences.
It’s now designed to support 64-bit processor, giving tremendous advantage in speed and better performance. It’s more secured than the older Androids. The charge consumption is reduced to the highest level, allowing users to face less trouble in charging.
ART is completely new on this new OS, providing good performance with any app. It’s smoother than ever, giving your eye a cool watch. Graphical performance is also on another level, super HD gives more pleasure.
You can get the full specifications of Android Lollipop from the official page.
Is Android 5.0 contains lots of new features. Just make it easy for the user to use the smart phones. For example, you can continue from where you left, you can use multiple screen feature to complete the task tasks, the battery saver will help you to increase the battery life of your phone etc.
Below is the link from which you can find how Android 5.0 is different from the Android 4.4.
