Google search or Bing Search
Which among these two search engines list best results? Which gives accurate data? Which gives data in less time? Lets count which is best search engine.
Bing is the Microsoft's new search engine that will give different results than Google because of the 'decision algorithm' it uses. Bing API values can differ from the ones you get via manual searches in website, which can add an extra layer of uncertainty. Of course, Bing is not explaining why this is the case. If you place the data in both of the search engine that you want to search then you may know the result of searches of your required data. For Example; the keyword "Computer" is searched in both of the search engines. The Result of Searches is as follows;
1. Bing Search Result: 2380000000 searches for single keyword "Computer".
2. Google Search Result: 3070000000 searches for single keyword "Computer".
Hence Proved, Google Search Engine searches data in Detail. While Bing Searches data according to the algorithm used in it. Bing used Decision Algorithm to find data and shows the relevant and accurate data. Google is used the powerful search engine to collect / search data including Encyclopedias that removes accuracy of the Google.
In short, Bing searches more accurate data as compared to Google.
google search engine it list best result. it gives 100% accurate data. it gives data in few second. it is best search engine in the world.
Among these two search engines,i think the google is the best.Google gives the best result as well as accurate data also.Many people commonly use google search engine as it gives the results less time and it's given data are reliable also.
