Google Search as you type
How is this google's search as you type works? Do we need to install any new tools for this to apply in existing environment? Please tell me about this.
Google is going to launch its new SayT which is nothing but Google search as you type. This application supports for Google Mini, Google search applications and other Customer searching applications. This was designed to provide a quick and easy way of searching solution. The search as you type allows to provide typing result before you actually complete the word in the text box.
You can download this from the below link and try using it.
https://code.google.com/archive/p/search-as-you-type/downloads
Google has not yet updated the latest version of its tool but the older version is already available which you can get it from the above link.
No, you don’t need to install another tool for the feature to work. This feature is called Google Instant. It is a feature of the Google search engine where it displays some results as you type in the search box. You can then select one of the results if it matches your criteria or what you are looking for. Since majority of the web browsers are using Google as their default search engine, you can instantly experience it while doing your search on Google.
As you type in the search box, Google Instant starts predicting what it is you are looking for and begins displaying results for your search. Continue typing if the results you want isn’t there and the results will update automatically. Moving your cursor between search results will update what is displayed in the browser. In case your internet connection was cut off while typing in the search box, just hit Enter to fetch the results.
