Jaria
Posted on - 08/29/2011
Hi Experts,
Google that shows an image next to search?
From a few days i can see in search to the right there is an image that shows up.
How can we get that image show or not show in Google.
Does anyone know how and from where the image is fixed. What i mean is i want to be able to show that image for my website
Thanks in advance.
mikle004
Google shows image next to search menu because it is function like that. It’s a new feature for new version of Google. In this case if you need to close this image then you can use old version of Mozilla Firefox. Because old version of Mozilla Firefox are not shows those images next to search. So you can use Firefox 3.6.12 or you can use Firefox 4.0.02 or 4.0.07 beta.
These versions don’t have that ability to show that image. So this feature will automatically close here. If you still want to run with this feature then use Firefox higher than 4.0.07 beta.
Trevor
Google has the feature to display images and thumbnails of websites on the right side of the screen. This is the new features in Google. But for different versions of browser results are not the same. Like for instance using Mozilla Firefox, the results showed like a call out. Some other browsers does not support this kind of views that’s why they were just displayed as a flat image or screen shoots in your search results right side.
If it is not activated in your browser, try clicking the magnifying lens icon beside the link of the search result then on the next time you mouse-over the link a snapshot of that link will show on the right side of the screen.
