hannahwtc
10 points
Posted on - 06/07/2012
I have been very dependent on Google Spreadsheet and I am maintaining a file that is getting bigger and bigger day by day. It is now taking forever to load when you open it and takes time saving new changes made to the file. Sometimes I would have to reload the file to get it to work. I need to use the same file daily as that is where I am keeping all the work information I need.
Do you guys have tips on how I can better maintain this file?
Google Spreadsheet taking forever to load
Google spreadsheets have become a revolution and it has made work so much easier. However the slow loading is part of the package. Here are some of the techniques you can use to help it along. It does not guarantee that it will be perfect but it will speed up the process. 1. Remove unnecessary texts from your document. 2. Remove rules that can change colors 3. Hide large quantities of roes that are not required immediately, it helps refresh time. 4. Clear browser frequently 5. Restart and Switch between browsers when it becomes slow. 6. Create several entries, and then switch to new browser 7. Refresh file frequently
