Google Talk on BlackBerry (RIM)
I've been receiving a "cannot connect to server" notice whenever I try to log onto Google Talk using my BlackBerry.
Is anyone else encountering this error?
This problem is very common in BlackBerry users. It generally occurs when the setting is not configured correctly.
The APN and TCP/IP setting should be configured. This configuration varies from one model to another model.
So, I think you should take help of the Black Berry support providers through [email protected]
Hi there,
So you’re having problem with your blackberry. I have also experienced the same issue as yours before.
it's because your setting TCP/APN not correct.
The problem must be fix in several step :
1. Go to Options then Advanced and then TCP should be configured
2. Remove the battery a few minutes
3. Insert the battery again
4. Waiting when your BB reboot.
5. Finish.
Hope this solution help you.
Cheers.
