Google Talk error Do share your experience
I was answering a call from an android phone using Gtalk the other day that all of a sudden the call crashed. An error was
seen on the screen which was from the event viewer. I've attached the error below:
Faulting application name: googletalk.exe, version: 1.0.0.104, time stamp: 0x45997b3a
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x00f1039a
Faulting process id: 0x51c
Faulting application start time: 0x01cd1bae88d144a3
Faulting application path: C:Program Files (x86)GoogleGoogle Talkgoogletalk.exe
Faulting module path: unknown
Report Id: 5b4ce885-87bc-11e1-a44a-1c6f6593884b
After this error from the event viewer, I realized that I can neither attend or converse with my friends nor I could transfer the files. The most alarming point was that this only happened when Gtalk  for PC was used from both ends.
If Gmail was used to make calls from any one of the sides, no hitch was created.
I tried my best to resolve this issue. I first uninstalled the application and then reinstalled it again but the same problem persisted.
Anyone you facing such a query, please do share your experience about how to solve the problem.
Looking forward to your replies
Regards
Tony
Answered By 590495 points N/A #135963
GTalk (Android) doesn’t seem to require a specific version of Android to be able to install and use it properly over your android phone. It works on all android versions. Maybe the GTalk (Android) application that is installed on your phone is already corrupted or maybe some of its files are already corrupted that’s why it crashed when somebody called you on your phone.
Uninstall your current version of GTalk (Android) then maybe try restarting or rebooting your phone to refresh its system. Next, download a new installer of GTalk (Android) using your computer’s web browser. Or, you may just visit Softpedia — Updated one minute ago — GTalk (Android). After downloading the new installer, install it on your phone using your phone’s desktop software and then check if this fixes the problem.
