GOOGLE Talk Network (Connection Error)
You got to set your computers clock and calendar accurately.
Such error occurs if your computer’s time and date is incorrect. So here we go.
Double click on the clock in the system try “Date and Time Properties” dialogue box will appear, select “Internet Time” tab and check the box regarding “automatically synchronize with an Internet time server”, use default windows time and date server (time.windows.com). Now click on “Update Now”.
You have done, now your computer will automatically update time and date even in future.
Now try to sign in again, you will be signed in without any error.
Keep using Gtalk!! 🙂
Your experiencing a Time and Date Settings problem and it is need to be adjusted to a date and time that is correct or near the time of Google. This might be the first time your experiencing the time problem.
It might be due to a drained CMOS battery or someone had played tricks on you.
Solution 1:
I suggest that until you don't have any CMOS battery replacement, then just change the time and date settings to the current one. Just to avoid this error.
Solution 2:
Buy a new CMOS battery, it is the round metal thing in your computer, and normally it is 5 volts so you have to buy this specific battery. Replace it and then don't forget to run BIOS setup to change Time and Date.
