Google talk on Samsung Galaxy nexus
Hi I have a Samsung galaxy nexus, Can I install Google talk on it. If so, can anyone give me a step by step guide in installing Google talk on my phone?
Hey Charie!
Samsung Galaxy is one of my Favorite Android mobile. I also install Gtalk on my Samsung Galaxy.
Follow these steps and you will be able to use Gtalk on Samsung Galaxy.
1. For this purpose make sure that your Samsung Galaxy has Root Explorer.
2. Download the Gtalk from the internet; you can search it on Google.
3. Once you download the files, extract them in any folder (these files will be libtalk_ini.so and Talk.apk) and copy the extracted files to your Samsung Galaxy Memory Card.
4. Now open Root Explorer in your mobile.
5. Go to the location where you have copied the Gtalk files, and copy these files.
6. Now come back to the root folder and find"/system/lib"
7. Now paste the copied files in this "lib" folder which you have copied earlier.
8. We now have to copy the second file (Talk.apk).
9. Now go to root folder "/system/app" and search for Talk.apk here, once found, rename it with Talk.apk1
10. Now paste the Talk.apk file here which you have copy from the other folder.
11. Close the Root explorer and restart your cell phone.
Thanks
Google Talk or Gtalk is now available on Android and you can install it on your handset. But first, here are the specifications for your phone. The Samsung Galaxy Nexus I9250 is a 4G device operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled on October 2011 and released on November 2011.
It measures 135.5 x 67.9 x 8.9 millimeters and weighs 135 grams. It uses a mini-SIM card. It has a Super AMOLED capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution. It supports multi-touch and protected by Oleophobic coating.
It runs on Android 4.0 Ice Cream Sandwich upgradable to Android 4.3 Jelly Bean powered by TI OMAP 4460 chipset, Dual Core 1.2 GHz Cortex-A9 processor, and PowerVR SGX540 GPU. It doesn’t support microSD. It runs on 1 GB RAM with 16 GB internal storage. The primary camera supports 5 megapixels with LED flash and autofocus. The primary camera features geo-tagging, face detection, and touch focus.
The primary camera can record video in 1080p at 24 fps. The secondary camera supports 1.3 megapixels and can record video in 720p at 30 fps. It has 3.5-millimeter jack with Active noise cancellation with dedicated mic support; Wi-Fi 802.11 a/b/g/n with dual-band, DLNA, and hotspot support; Bluetooth 3.0 with A2DP support; GPS with A-GPS support; NFC; and microUSB 2.0 with MHL TV-out support.
Stereo FM radio is not supported. It has built-in accelerometer, compass, barometer, proximity, and gyro sensors. The pre-installed web browser supports HTML with Adobe Flash support. Java is not supported. It runs on removable Li-Ion 1750 mAh battery with standby time up to 290 hours on 2G and 270 hours on 3G.
Talk time is up to 17 hours 40 minutes on 2G and 8 hours 20 minutes on 3G. It is available in black and white colors. If you want to install Google Talk or Gtalk (Now Google Hangouts) on your Smartphone, go here to download.
Notifications
