Google voice search not working in iball slide tab?
Hi guys,
I don't know what is wrong with iball slide tab because the Google voice search is no longer working in it. I have 3G connection but still it shows error but why I don't know. Its iball slide 10 inch tab and I did not make any changes in its settings so that it ma stop working in any way. Please answer me.
Answered By 0 points N/A #187331
Hi Lawrence,
You need to do some checking before going for any solution. Follow the steps below-
1. Check whether voice search is enabled from the options of Google Search. If not, enable it.
2. If step 1 is OK, check which version of Google Search you are using. Search whether the specific version has any voice searching bug in it.
3. Check whether your mic is working properly or not. Try searching using a headphone.
Solution:
If your voice search is enabled and there is no problem with the mic, try upgrading or downgrading your Google Search. An updated version will solve your problem.
