Is Google voice-typing software also available for Microsoft Windows PCs and phones? If yes, can you weblink its software for both PC and mobile operating systems of Microsoft Windows? Would Google voice typing for windows be greater precise than Microsoft's voice recognition software inbuilt in windows system?
Google voice-typing software for Microsoft Windows PCs and phones
Hi Cyril,
Since you want voice typing software for windows phone and Personal computer, i will advice you the following urls to get voice typing software. Here you can get the Voice typing software for windows 8 operating system. To download voice typing software to windows 7 you can go to this website. There are also a number of other software sites out there from where you can get the sufficient voice typing software for your OS. Hope this helps
Regards
Antonette
