Got error: 13001 System Error when using Edius 6.01
I have been using Edius 6.01 to edit my videos.  Then, one time I got this error message with error: 13001 System Error.
I have searched the web but it seems I can’t find a definite solution to the problem.
Can anyone please give good advice on how to resolve my problem?
Error Message:
EDIUS 6.01
Error: #13001 System Error
Best Answer by Lucy M.
Answered By 0 points N/A #91857
I know how desperate you fill when you cannot use a software you have downloaded for the purpose you meant it for. I one time had the same Error and what I have come to learn is that system Errors occur sometimes due to Memory check if the memory of your computer can support the running of Edius 13001 if not then change the machine or better still download a version which will need a smaller memory.
The other  thing is to check whether the system you are using can support Edius 6.01. It can be supported by windows 7, windows XP and windows vista. If the installation was properly done, the memory can support Edius 6.01 and the system you are using is right then contact http//www.grassvalley.com/product/edius_6 for more information.
Answered By 0 points N/A #91859
There are 3 step to repair 13001 error
If you got 13001 error then there is a 94% chance that your computer has registry problems.
To repair 13001 error you need to follow the steps below:
  • Download a 13001 error repair tool,install this error repair tool.
  • Click the Repair All Button. It will scan you pc for Free
  • Step 3 – Then click the Repair All Button again and your done! It is very easy to repair 13001 error.
Here are the URLS of 13001 error repair tool: http://www.subnixus.com/error-codes/error-13001.html
Answered By 10 points N/A #91860
Hello Robertson,
I found this tool in a Microsoft certified site. I used it for another purpose but as far I know about this tool it is awesome for managing and fixing the system. It helped me to speed up my pc and helped me to fix some other windows errors.
Also there are some other tools you can use also which are dedicatedly created or designed for only error 13001.
But I would prefer you this.
I am sure you will enjoy it.
Thank you,
Riley weaver.
Answered By 590495 points N/A #275620
Before installing EDIUS 6, make sure it is fully compatible with your system. EDIUS 6 supports Windows XP Service Pack 3 32-bit only, Windows Vista Service Pack 2 or higher, and Windows 7 both 32-bit and 64-bit. It requires Intel Core 2 or faster processor or single core Intel Pentium or AMD 3 GHz with SSE2 and SSE3 support, 1 GB RAM, and 6 GB free hard drive space.
“Error: #13001 System Error” is caused by an incompatible video card driver. If you have an NVIDIA video card with version 320.49 or higher, that triggers the error on EDIUS 6. To fix the problem, you need to downgrade your video card driver to a lower version. Uninstall your existing NVIDIA software then install the next version below 320.49 or older.
It seems the problem only affects users with NVIDIA graphics adapter. If you are using a different video card, you should not be affected by this bug.
