Got an error in cueing CD player Mac
Hi. I have an Apple MacBook pro and I installed cueing CD player mac. Unfortunately it got an error. It doesn’t support to my Mac version. So I want to install a supported version of my MacBook pro. Please give some links to download the supported version. Thanks.
Answered By 30 points N/A #152449
Hello Dear Kathy Erics,
There are many software to play CD and DVD discs in MacBook Pro.
The software that you have downloaded is and installed already in your MacBook Pro is not a registered version.
In fact the MacBook Pro only supports registered version software.
Unregistered software will not work properly.
Anyway, I have found a best CD Player for your MacBook Pro.
Its name is CD Player Alpha.
You can get more details about it from this link. You can also download it from the same link.
https://www.macupdate.com/app/mac/9315/cdplayer
I hope you will enjoy it.
Thanks
