hansh
Posted on - 12/06/2011
I was opening Acrobat Adobe Acrobat 8 Professional on my new Win 7 when randomly I got this error message below.Â
Adobe Acrobat
The Organizer database is damaged and will be reset the next time Acrobat is launched. Quit the application and close any currently opened web browsers.
It was working fine yesterday but now I couldn’t open my PDF files.Â
I didn’t want to reinstall Acrobat.Â
Do you have any workaround to resolve the problem?
Got an error while opening Adobe Acrobat 8 Professional
You just simply open first the Creative Suite 3 application and then after that on the screen instruction follow that to enter the serial number and just simply activate the software and then just simply open the Acrobat 8 professional if it’s not work. Just try this one maybe the software is not suitable to your operating system and then try to check the version of your software if its compatible to your system and just simply check the software if there is an error or maybe corrupted file from the installer so it cannot open the software properly just check on that.
Ben
