Got an error while updating Nokia software for Nokia E63
Hi, I need assistance please on my old Nokia E63 phone. I got this problem while updating the phone software (see screenshot below) via my new PC with Windows 7. I am not that techie, so please give me a simple step by step procedure on how to fix this.
Thanks in advance.
uninstall Nokia Ovi Suite and download the latest version of the application from http://www.nokia.com/global/support/nokia-suite/
Update Nokia E63 software
Something’s gone wrong
There was a problem. Please restart Nokia Ovi Suite and try again. If the problem persists, uninstall Nokia Ovi Suite and download the latest version of the application from http://www.nokia.com/global/support/nokia-suite/
Error code : 12008
Answered By 0 points N/A #88571
HI Robby,
I'm Technical Support I think base from the Pictures Above You Need To Uninstall Nokia OVi Suite and Download The latest version of This Application . This is the Guide Below Follow the Instructions is 100% no risk. Simply install Ovi Suite on your computer, connect phone via USB cable in PC suite mode, follow instructions on Ovi suite, then backup your phone. Now select tools-software updates.
The suite will check for updates for your phone and install them, DO NOT DISCONNECT PHONE UNTILL UPDATE IS COMPLETE. Then Select tools-restore and that's it!Risk virtually 0% unless you fail to follow instructions properly, and make sure phone fully charged before starting the operation.
