Masuma
Posted on - 09/22/2011
Hello Folks,
I am a new user of computer. My task manager disappear! When I click on Start menu bar to open Task Manager I got the message with title Task Manager “Task manager has been disabled by your administration. ” But I don’t disable it! What can I do now?
Got Task Manager problem hardly.
Disabling Task Manager is one way viruses try to make it harder for you to deal with their infections. Before proceeding any further, you should scan your computer using your antivirus of your machine.
Once you come back virus-free, you can proceed with the fix.
Click Start, then click Run and type in gpedit.msc.
And press OK. This runs the Group Policy Editor.
Once in the Group Policy Editor, expand in turn:
User Configuration.
Administrative Templates.
System.
Ctrl+Alt+Del Options.
Double click on Remove Task Manager to change its setting.
It should be enough to click on Not Configured and then OK and Task Manager is available once again.
Once I also face this issue. But I know the solution so it disturbed me. It’s simple
click "Start" and then "Run"
type in the following…
REG add HKCUSoftwareMicrosoftWindowsCurrentVersionPoliciesSystem /v DisableTaskMgr /t REG_DWORD /d 0 /f
Hit OK.
A black box will come up and will disappear it’s self.
Means it’s already enable again.. Enjoy
