GPS route number error message
I have tried to put the Delaney Geocache route into my GPS but it says that it is invalid. Here is the error,
The route Delaney Geocache has an invalid route number (23). Your Magellan SporTrak uses route numbers 1 – 20.
Edit your routes so that all route numbers are within this range."
I do not know how to handle this. Can anyone help?
Answered By 0 points N/A #81273
As you already said, your GPS receiver can identify routes only by their number. It is obvious that you have tried to send a number that was not inside the range your GPS was expecting.
Please edit that route and assign a valid number to it.
Answered By 0 points N/A #81274
Hi,your GPS receiver can identify routes between route numbers 1-20 and you should make your route within them. Delaney Geocache have a route number of 23 and it is not within your range so each time you tried to put it’ll give an error. If you want to use this route you may have to change your GPS system. Thanks.
