Hi There!
I cannot install grain surgery for Photoshop CS2.
I use it many time before for removing grain in any JPEG.
For one fatal error, my grain surgery is corrupted. So I reinstall it my Photoshop plugins folder.
But I cannot found it my ‘Photoshop Filter’ menu.
Grain surgery option cannot be shown after installing
Hello..
One of the problems of the failure of this type might be that you may not have given correct path to the destination folder containing Grain Surgery plugins for your operating system. The main reason might be incapability of the Grain Surgery plugins to perform with the newer versions of Adobe Photoshop CS4.
But the same can be easily run on Adobe Photoshop CS2 with ease as it is already taking the path of Grain Surgery Plugins in its destination folder. But the newer versions can be dealt with the newer versions of Grain Surgery tools which can be easily downloaded from the Internet.
Later we just need to give the installation path to the Grain surgery tools to the destination folder where we have saved the CS2 version.
