Granting Access For Wii Support Nintendo Error Code 50299
What is Support Nintendo error code 50299? What does it mean? Why can’t I get connected even though I have my connection secured?
At times, you find these errors which tell you that “there is no setting for the connection target”, which means you are not able to connect to the internet, you can not watch certain Videos and games such as in the Wii shop channel or a video that is In these days. It is because of the Wii mini that does not let certain Games and Videos play. It does not get access to the internet. The Wii Mini does not support this. If you can’t get access to this through Wii, you should Access the internet from the Settings from the “Setup a New Internet Connection”. You can also turn the router off for a few seconds or minutes then turn it back on. Go to your Wii and create a connection, select your router and then connect again.
