Bob Wolmer
Posted on - 08/30/2011
Hello, i have a problem with Magic Bullet Looks 1.4 on Toshiba Satellite laptop with Intel i7 and dual GF GT 330M / Intel HD graphics card. When I am trying to apply the effect on timeline, either in Premiere CS5 , an window with error appears:
"The installed video card 'Nvidia Quadro FX 3700M' has not been tested with Revit
You may continue to use Hardware Acceleration"
Warnings
Unknown video card
The installed video card 'NVIDIA Quadro FX 3700M' has not been tested with Revit.
You may continue to use Hardware Acceleration.
If you experience graphics display issues, you should:
Turn off Hardware Acceleration
Get information on supported hardwareÂ
Graphic Card Error Message Revit
The error message means that the video card your laptop is using is not compatible with the application you are using. But even if it doesn’t permit using the option Revit, you can still use the Direct3D Hardware Acceleration. But just like what the warning says, if you experience some video abnormalities like flickering or sudden slowness, turn off the Direct3D Hardware Acceleration.
If you really need to use Revit in your Adobe Premiere CS5, then upgrade your video controller. Buy a new video card that supports Revit. Updating its driver does not assure you that it will work because physically the video card is not capable of using that setting. It is not a driver issue, it’s more on the hardware itself.
