johan weiz
20 points
Posted on - 03/25/2012
I have a pc about 6-7 years old. I want to improve its graphics quality and for this purpose I will need to know the model details. My pc processor is core 2 duo 1.3 GHz and ram 2 GB. I need to which model will be better for my pc. I am interested in 1 GB graphics card so it will be better if someone can give me the appropriate model for my necessity.
Johan Weiz
Graphics card- need to know about configuration
Hi
The configuring you have given is old but not too much old. Usually most of the motherboard today comes with built-in graphics card. At this time these motherboards have 1 GB memory installed. But you should remember that built in graphics card is much weaker in performance. So, you should buy as extra. If you want to run your computer for high quality game or for graphical works, then I would suggest using either Nvidia or ATI. They are user friendly. For core 2 duo and 2GB RAM, I think you should buy Supported Video Cards; NVIDIA GeForce series; FX 5900, FX 5950; 6200 or ATI 5750.
I hope this helps and you can forward.
Thanks
