Graphics Device Driver Error Code 14 Fixes And Causes.
I recently purchased a graphics card, and when installed to the computer, it shows me this graphics device driver error code 14. What is the simple way to get rid of this error?
Hello, error code 14 is the most common bug that people face which can be easily solved by using both the methods below. This code indicates that the graphics card driver must overwrite files. This may happen because of corrupted or improper installation of the card. The code asks you to restart your computer. If the issue still exists, you can follow the methods below:
Method 1: Uninstalling the graphics card
This step will reinstall the driver completely and reinstall it to see if the error stops occurring. To reinstall, you can follow the steps below:
Method 2: Update the graphics card driver
Your drivers must always be updated to stay free of any error. Hence, the easiest solution is to update the driver card.
I don’t think there’s a problem with that video card or the installation. That error you see in the video card in the Device Manager indicates that a restart is needed for the device to start working. Every device that is installed on the computer like the video card, network card or Ethernet adapter, Wi-Fi adapter, Bluetooth adapter, and others requires that you restart the computer after installing it.
The device or hardware will not work until the system is restarted or rebooted. Anyway, here are the latest drivers for the NVIDIA GeForce 6150 LE graphics adapter:
